TwinTurbo.NET: Nissan 300ZX forum - my suggestions:
Subject my suggestions:
Posted by nemo1080 (Iowa) on April 10, 2008 at 4:08 PM
  This message has been viewed 196 times.
In Reply To engine rebuild questions.. posted by PearlZX on April 10, 2008 at 02:24 PM
Message forget the cometic head gaskets. use OEM with ARP studs!! Proven good to 1200 RWHP! ARP stud kits can be had through conceptzperformance.com
also, forget the OEM motor mounts, way to expensive, use the Ford motor mounts that are described in the auto-faq.
you never mentioned bearings, I suggest having the machine shop you use to bore the cyl's for the new pistons, measure your crank and block and order the appropriate bearings. Clevite is a good name for those.
Get a new oil pump, OEM.
best prices on 120k kit and engine gasket kit is CZP.us
your eagle rods will come with arp rod studs.
if you do lifters you should prob use OEM unless your getting cams and diff valve springs.
It's not turbo lag, It's foreplay! Click Sig for My local forum!
" A Z was stolen But apparently to everyone here it's more important that the D key is not to the E key and she missed.
Do you people have souls? Seriously, this is pretty fucked up."
- Pacmanpth
